open- or closed-loop?
Old Feb 13, 2004 | 09:46 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Short of hooking up to a diagnostic computer, is there a way to tell if running in open or closed loop? 89 350 TPI very little mods (yet )
Old Feb 14, 2004 | 09:29 AM
Vader's Avatar
Yes, you can tell if the ECM is in open- or closed-loop mode, and determine if the system is rich or lean, simply by entering the Field Service Mode.
Field Service Mode
On the OBDI ECMs, you can jump 'A' and 'B' terminals on the ALDL while the engine is running.
WARNING! This must be done after the engine is running. This is called "Field Service Mode" and will not harm the ECM.
If the ECM is in Open-Loop mode, the SES light will flash rapidly, about 2½ times per second. If it's in Closed-Loop mode, it will flash about once per second. When in Closed Loop mode, flashing less than once per second indicates the ECM is enriching the mixture above the 128 count base line. Flashing more than once per second indicates the ECM is leaning the mixture below the 128 base line.
Eric2ndGen
Nov 5, 2015 01:51 PM
SCCAjunkie
Feb 19, 2012 03:06 PM
BWilcox
Mar 15, 2010 09:23 PM
mightyfbird88
Apr 13, 2006 09:55 AM
LinuxGuy
Jan 13, 2005 06:38 PM
