1987 firebird vibration
Old Feb 16, 2004 | 03:45 PM
knight75's Avatar
Car: 1987 Pontiac T/A with Knight Rider conversion
Engine: 2.8 V6
Transmission: 700r4?
Hey guys I was wondering if anyone could tell me what could possibly be causing my firebird to vibrate. Its usually pretty bad when I 'am traveling the intersate. The car vibrates and so does the steering wheel. Any info would be Great! Thanks everyone!
Jason Burnett
Old Apr 3, 2006 | 05:17 PM
ss-35th's Avatar
Car: 1990 Camaro Iroc Z28
Engine: 5.7 TPI
Could be your tires need balancing or if you have a steel driveshaft it could be out of balance.
Old Apr 4, 2006 | 10:47 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
My 87 TA had a vibration between 45-65 mph. Turned out to be a worn out ouput shaft and yoke on the tranny.
I upgradded to a factory aluminum driveshaft to help fix the vib when I changed the yoke and output shaft.
Old Apr 4, 2006 | 12:30 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Start with the simple stuff. Most likely out of balance tires, a separated tire, or a bent wheel.
And dont forget anything on that rotating assembly that isnt even will cause a vibration. Lugnuts with large size or weight variations, heavier valvestem caps like the light-up ones or something (need to be on the wheel when it's balanced), and something inside the tire like fix-a-flat can all cause vibration issues.
(Fix-a-flat itself will disperse when you get up to speed, but what causes the vibration is most wheel balancers will not spin a tire long enough to let the fix-a-flat spread around, therefore you get an inaccurate readout from the balancing machine and shifting weight numbers making it virtually impossible to properly balance the tire.)
Old Apr 4, 2006 | 12:44 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Yup, while its in the air for the tires, grab the driveshaft near the yoke at the tranny end and see if the yoke has any slop in the tail housing.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Americanmouse
Sep 7, 2015 12:10 PM
transamgta87
Sep 1, 2015 07:07 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
