what gaskets do i need
Old Feb 16, 2004 | 05:31 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Ok, I got a new intake Im installing on my TPI. Plenum, runners & manifold. Do I need to buy an engine kit or do they sell a kid with the parts I need. I hear tat FelPro is good. Also my car smokes at startup will this fix it or do I need to go deeper. If so how deep? what else needs to done.
Thanks for the info
Old Feb 16, 2004 | 06:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't know about the gaskets - never needed to look into it.
The smoke-at-start-up is most likely valve stem seals. The intake gaskets won't change a thing. Small block Chevy's are well known to have the seals harden and crack, producing the symptoms you describe.
Old Feb 17, 2004 | 06:00 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
You need an intake manifold gasket kit.
Valve seals would be the problem with your smoky startup.
Old Feb 17, 2004 | 08:36 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yeah you will need a lower intake manifold set.. This will include the upper set (for runners and plenum) along with the base manifold to cylinder head gaskets and distributor gasket.. Felpro is good.. Just make sure to use RTV around the water jackets...
Old Feb 18, 2004 | 06:04 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I didn't because Helm's didn't call for it. No leaks yet.
Old Feb 18, 2004 | 07:13 PM
thirdgen88's Avatar
Car: 1995 Corvette
If you use felpro performance gaskets, they have an integrated sealing bead in them... The ones that come with a intake manifold set do not.. So you have to use sealant on those or they will leak...
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
