Something odd with fuel pump....
Old Feb 16, 2004 | 09:18 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Today while cleaning my car, after I moved it onto the driveway and turned it off, I heard my fuel pump continue to run (same sound as when you turn key to on postion). I started the car up again and it fired right away. Turned it off again and heard pump go again. I've listened for this sound before but I don't think it does this all the time. I will be sure to listen for it next time I drive the car and turn it off. Is the pump supposed to continue running after shutting car off? Could my hard start problem be the result of the pump not continuing to run after the car is turned off?
Old Feb 16, 2004 | 11:12 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
same thing happened to mine.....it was the oil pressure/fuel pump sending unit .....just my .02
Old Feb 17, 2004 | 02:01 AM
sixbanger's Avatar
so is it supposed to run after the car is turned off?
Old Feb 17, 2004 | 06:13 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
No, sounds like a bad relay.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Warlocksirix
Sep 3, 2015 12:26 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
