what kind of fan should i have?
Old Feb 6, 2001 | 03:32 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
My car is an 84 Z28 with L69 5 speed, 3.73 gears with no A/C. I bought the car with the original engine all torn apart and out of the car. When I was rebuilding it I realized I was missing a fan shroud and a fan.
I went to a chevy dealer and bought a new shroud that seemed like it was for a fan attached to the waterpump (old style).
I headed to the junkyard and found a good clutch type fan and bolted it on. It works great but I am sure it is robbing horsepower. Did my car come originally with an electric fan?
Old Feb 6, 2001 | 04:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. The clutch fan will cost you several HP. Definitely get the electric!! You can find the assembly at boneyards without too much trouble, then buy a new motor if it needs it, they're not too bad.
ICON Motorsports
Old Feb 6, 2001 | 05:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Were you missing only the lower fan shroud? Not all cars had them.
Old Feb 6, 2001 | 07:42 PM
Tom84L69's Avatar
Car: 84 Z28
Thanks, my motor is great now. It can give a new LS1 6 speed F-bod some trouble!
And I was missing both top and bottom, the car had an engine fire before i bought it. It was a mess, all the wiring and plastic stuff was fried!
I need to find some electric fans.
Old Feb 6, 2001 | 08:37 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I would suggest getting the dual electric fan set up from a 87-92 Z or T/A.I beleive(I could be wrong)that they were available on the 5.7 cars,i got mine out of a 91 Z28 5.7.Car runs cooler than it did with the block fan,even with the new motor,355,AFR heads,10:1,Comp Xtreme energy.Just a suggestion!Got it cheap too,paid $15.
Gunner242
Dec 25, 2015 04:49 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
hartsmike
Oct 2, 2015 07:11 AM
