make more vacuum for brakes?
Old Feb 17, 2004 | 11:53 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
is there anyway to creat more vacuum for the brake boost???
Old Feb 18, 2004 | 05:43 AM
ede's Avatar
ede
change in cams and timing will change engine vacuum. easiest thing to do is add a extra vacuum canister. that won't really make more vacuum but it'll give you more vacuum for the brakes.
Old Feb 18, 2004 | 08:10 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: make more vacuum for brakes?
if you dont have enough Vac to run everything, you can get a electric vac pump... they run off a lil electric motor, and only run to create a vacuum.... once it reaches the set level, it shuts off... so its not always running..
you can route your air doors and other non engine, vac accessories to it too..
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
