Engine Shave heads .020/.015 Fel Pro Gasket
Old Feb 18, 2004 | 09:38 AM
1993GMCPU's Avatar
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
I was wondering if anyone has used this Fel Pro 1094 gasket and since in the country, we only have a few local machine shops that said they would shave heads .010-.02 only-50.00 dollars. Tulsa, well they shave and surface intake side of manifold for 150.00 dollars!
Since funds are tight right now, I wondered if you forsee any problems as motor was just machine and all new parts in 4 bolt main less then 10,000 miles. Just heads that were suppose to be on it were 76 cc SR's not 67 cc Torkers, which screwed me up on compression etc. They were to replace heads, but only got bare castings and for now, I need to get vehicle running. Does anyone see a problems with doing this?
Thanks :hail:
Old Feb 18, 2004 | 09:59 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
https://www.thirdgen.org/techbb2/sho...hreadid=224242
Hope that helps.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
