Rubber Problems
Old Feb 5, 2001 | 06:58 PM
Spyder's Avatar
Rubber Problems
Okay, right before I put my car into storeage I was going down the freeway a, "little" over the speed limit. Then some lady just cut in front of me going to more then 30mph. Needless to say I slammed on the breaks and considering I was soo luck not to have ABS I lit all four tire up. So afterwards I noticed that I had a vibration in the car. I figured that it was flat spots that had developed on the tires; does this sound right. I slid for a good 100 feet at 80+mph. So no problems on the back, lit them up a couple times and have had no problems since but what should I do about the front? They are brand new tires and I don't wanna get new ones.
Old Feb 5, 2001 | 07:14 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Just rotate them and burn rubber again.
Or are they the IROC/GTA wheels that are different front and back??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Feb 6, 2001 | 03:28 PM
Spyder's Avatar
They are the directional front/back 90-92 alloys. The thing is too I don't want to dismount them, I don't know if any one does this themself but a 45 side wall on a GSC is not the easiest thing to dismount/ mount. Can I throw them (the front rims) on the back of a S-10?
Old Feb 6, 2001 | 10:10 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
I'm not familliar whether or not the front and rears are the same size on the 91,92s.
If they are the same size, just rotate them front to rear.
As far as an S10 to burn them in....can a S10 burn rubber??
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Feb 6, 2001 | 10:40 PM
Vader's Avatar
Spyder,
The front wheels will fit and clear on the rear axle, but the rear wheels might not clear the steering knuckes and tie rod ends on eh front end. If you can get some "loaner' wheels or spacers to install the rear wheels on the front temporarily, you can mount the fronts on the rear axle and burn them to your heart's content.
They must be a pretty soft rubber compound to flatten after one hard stop - then to "clean up" after a few burnouts.
Later,
Vader
"I know how to solve your problem, but I can't tell
you since you might use the information illegally...
Adobe Acrobat Reader 4.0
Old Feb 7, 2001 | 11:11 AM
chris1roc's Avatar
I don't think that burning out will help. I think that you will probably have to buy new ones. But if you want to try, Vader is right about switching the wheels from the front to the back.
88 iroc
305 tpi
k&n, flowmaster, ADS chip
home made ram air
removed smog pump
ASCD big block hood
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
