Bolt size
Old Feb 19, 2004 | 10:31 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Bolt size
anyone know the bolt size on a gm ac clutch...the four that hold the spring assembly together....???/ hope, hope, hope,
Old Feb 19, 2004 | 11:52 AM
Vader's Avatar
Spring assembly? Is this for a Frigidaire/Harrison R-4 compressor?
Old Feb 19, 2004 | 12:11 PM
Engine: 406
Heck I dont know vader..Its on the LT-1..if I'm looking at the clutch there is a center bolt and 4 surrounding..the compresser is still in the car there is one bolt of the 4 left but I hate to take it out for fear of the whole thing coming apart on me...Ive never assembled one before......
Old Feb 19, 2004 | 12:24 PM
Vader's Avatar
I just looked at both my LT1s, and they each have only three bolts through the clutch face. Am I looking at the wrong part?
Old Feb 19, 2004 | 12:33 PM
Engine: 406
That very well could be..I was reaching down in the dark early this morning with a flashlight..that steel plate tween the outer piece and the pully had pivoted out off center and whas causing an unbelievable out of balance shudder when I pulled her off the freeway!!! Any Idea what size and length those bolts are?
Old Feb 19, 2004 | 01:06 PM
Engine: 406
UPDATE VADER...3 bolts..1 is sheard off 2 are gone any Idea what size? length
Further update: All three are sheared... Looks like Ill be pulling the whloe unit after all. Thanks anyway, Vader.
Old Feb 19, 2004 | 01:47 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Bolts? Should be rivets. I pulled a new front clutch plate off the shelf here at work & they are riveted together.
Old Feb 19, 2004 | 02:30 PM
Engine: 406
well, whats left of mine looks like busted off bolts..3/8 or 5/16..hmm either way I have to R&R or go with a A/C delete pully setup. Funny thing is , they want $190 for a rebuilt clutch. Or $210 For the whole thing , clutch and comp...Go figure?. I may just settle for the 35 dollar delete setup..who needs air when ya got T-Tops right
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
