Few ?'s after intake install
Old Feb 8, 2001 | 04:09 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
First off Everything runs good now but I went around the whole engine with carb cleaner to maybe find intake leaks, so I did find on the last 2 bolts on the pass side intake. I tightened them even more like 40LBS then the only leak i can find is the fuelinjector for # 8 cylinder. If i spray down the bore with the injector in i can hear the engine stummble just a tad so i tighten the fuel rail even more but it still does it any suggs?
also the engine doesnt smoke one bit, and I have no coolent loss but when i changed my oil afterwords it looks a little bubbley when i pulled the dipstick out. Is that just cause I had the car running? Thanks
Old Feb 8, 2001 | 07:18 PM
Guest
Guest
Posts: n/a
Might be that the o-ring on the injector is damaged. Is this an aftermarket manifold, like and edelbrock? Just curious... might be a manufacturing defect, they seem to have alot of those.
Bubbly... check it again see if its the same. Generally oil doesnt form bubbles that stick around too long. Maybe theres some coolant residue still in the oil. Keep an eye on the oil and the coolant just to be safe.
Old Feb 8, 2001 | 07:23 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Its an Edelbrock intake. Oil Pressure is 55 PSI No Coolant loss 190 TEMP. No smoke blowing I let it run 20 minutes and ideled perfectly. With coolent in oil pressure be differant?
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mdtoren
Aug 23, 2015 12:52 PM
bryan623
Aug 10, 2015 11:33 AM
