starter motor removal
Old Feb 24, 2004 | 06:29 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
my starter went out on my 85 trans am and i was just wondering what all need removed to get the thing out should i remove my crossover pipe to get it to fall out or will it fit out without taking them off
Old Feb 24, 2004 | 06:51 PM
Vader's Avatar
If you still have the stock Y pipe, you should not need to remove it. You may have a forward starter brace that will need to be removed, or at least loosened and swung out of the way, but th estarter should come out through the opening. Be careful of the detonation sensor and its connector when removing and installing the starter.
Old Feb 25, 2004 | 02:02 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Be sure to disconnect the negative battery cable before removing the cables from the starter...
Old Feb 26, 2004 | 04:27 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
I just installed a starter on a 1991 LO3 with stock exhaust. At first it looks like you might have to drop exhaust but you don't. Just take your time and play around with it and the starter will come out w/o messing with exhaust/y-pipe. As mentioned above the knock sensor is fairly close so watch out for that.
Old Feb 26, 2004 | 05:34 AM
ede's Avatar
ede
takes a little bit of manuvering but they'll fall right out, no need to do anythnig extra to r&r the starter on a thirdgen.
Old Feb 26, 2004 | 02:37 PM
Engine: LO3 and LT1
i got it. it ended up falling out on me when i went inside to get a socket. came out and it was laying on the ground
Old Feb 26, 2004 | 03:31 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Put a newer style starter on it...you'll be glad you did. I asked about them on here and did a search on them...I assume 85's will work with the 95 Z28 starter.
Whoops...sorry I just noticed you have a pontiac....sorry bout the reply...
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
mhatfield 14
Aug 15, 2015 10:47 AM
milk
Aug 10, 2015 06:26 PM
3rdgenparts
Aug 8, 2015 07:09 PM
