whats the specs on the lt-1 cam?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i hear everyone saying replace my ****ting peanut cam with an lt1 cam, well im curious what are the numbers on the lt1 cam?
Car: '02 Z06
Engine: L33 5.7
and heres a cam i had in mind from jegs, the specs are
Serious performance for modified 305 5-spd. & 350 w/3.73-up.
Adv. Duration: 272º/284º
Gross Lift: .454''/.480''
Series: 2050
and since i soon will have my 3.73's installed, will this be a nice edition?
remember, im in cali and everything i buy has to be 50 state legal, so dont be recomending i get something that wont be emmisions legal (unless it is undetectable and wont effect emmisions)
Series: 2050
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
Re: whats the specs on the lt-1 cam?
Car: '02 Z06
Engine: L33 5.7
oh thanks! this forum needs to be cleaned up so the search actually helps
or even better, if u could use quotes in your search
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Series: 2050
Series: 2050
Car: '90 RS
Engine: 377 LSX
would they be fine if i had the sr torquers?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Originally posted by ShiftyCapone
Yes. The SR's can take about .525" lift out of the box and have larger valves to take advantage of that larger duration.
Car: '90 RS
Engine: 377 LSX
Originally posted by Stekman
Not to mention, they probably have a better flow rate. (assuming your heads are unmodified)
