dual snorkel on lg4
Old Feb 29, 2004 | 11:32 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
dual snorkel on lg4
Hi,
Does anybody know if I can use a HO dual snorkel aircleaner on my lg4 and if I would gain anything?
Old Feb 29, 2004 | 11:38 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
yes it will fit, you'll gain a tad more, maybe a little noticeable, i have one, i wont go back
Old Feb 29, 2004 | 01:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It will fit fine, and it will breathe ALOT better.
Old Feb 29, 2004 | 04:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Camaro, I assume? The dual snorkel and a KN filter will impress you.
JamesC
Old Feb 29, 2004 | 05:11 PM
Parrydise7's Avatar
The only problem I had is with that hot air tube. It doesn't hook up. It doesn't seem to make a difference, but I did keep my old single snorkel for when I have to pass smog.
Old Feb 29, 2004 | 05:28 PM
JamesC's Avatar
The heat stove tube, which connects the exhaust manifold with the driver's side snorkel, fits exactly like your stock piece--the whole business is a direct replacement. How would smog be affected? One suggestion: when you swap a dual snorkel in make sure that both vac motors function. If not, the doors won't open and as a consequence, you won't experience the bennies of the set-up.
JamesC
Old Feb 29, 2004 | 05:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
In CA, that tube has to be hooked up, like every other emissions-related piece that came on the car.
But, it's on the same side. You can just go to Auto Zone or Checkers and get a piece of that tubing (it's 1¾", hangs on a rack not far from the air filters) amd hook it right up.
That's the best posible air cleaner you could use. It gives your engine 2 ducts instead of one, of cold air instead of hot under-hood air like an open element would. It;s the way to go.
Incidentally, the vacuum closes the doors when it's cold, it's not needed to open them when hot. Their "normal" position is open.
Old Feb 29, 2004 | 06:06 PM
JamesC's Avatar
Brain fart
JamesC
Old Mar 1, 2004 | 03:02 PM
Marc 85Z28's Avatar
JamesC
It impressed me! Even on a bone stock 305 it made a very noticable power and sound improvement.
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
