305 tbi question about heads
Old Feb 26, 2004 | 08:55 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
okay i want to get my compersion up and im going to use a lt1 cam in my 89 formula tbi so wuz wondering how much can i get the heads milled down to raise comperssion on the lil 305.also is that even a possibilty and if so how much do,places usually charge for this.and should i jus find some 305 TPI heads instaed or stick with the tbi 305 heads.
Old Feb 26, 2004 | 09:02 AM
cgb's Avatar
cgb
Even though I'm a tightwad, I always spend as much as I can on the cylinder heads...this doesn't always mean more money, maybe just shopping around.
Check local engine / race shops / machine shops, alot of times you can find good deals on parts that people never picked up and the shop just wants them gone.
Old Feb 26, 2004 | 10:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Compression isn't the problem on LO3/TBI heads. Swirlports is.
Putting an LT1 cam into an engine with shaved swirlport heads will drive a need for higher octane but will not produce more power.
The first thing to replace on a TBI engine is the exhaust. The 2nd is the heads.
Then you can consider a cam swap.
Old Feb 26, 2004 | 10:59 AM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
I agree with him. if you want to make your car faster, you have to have a balanced combo. you can only put as much cam through the motor as the rest of the top end can flow. otherwise it would be like splicing in a foot long peice of 4" exhaust between your cat and muffler, while the rest of the system is stock. it ain't gonna work very well....
Old Feb 26, 2004 | 09:13 PM
tbfirebird's Avatar
Engine: ??????????
well ive got full exhaust done headers and catback but what should i do with the heads cuz i got the lt1 cam.and im going to put it in.
Old Feb 26, 2004 | 10:23 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can run the stock heads without a problem. They are garbage don't get me wrong but they will work. A head swap will make that cam really shine. A cheap solution is a set of 305 TPI heads that can be had for around 100.
Old Feb 27, 2004 | 06:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The heads you want are casting # 081. They're not just TPI heads; they're also on 87-up LG4 and L69 motors. So look in Monte Carlo SSs and base-model (carbed) 87 V8 Camaros and Birds for them too.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92purpz28
Aug 11, 2015 02:30 PM
