Charging Problem and Transmission not kicking down after engine install
Old Feb 26, 2004 | 09:24 PM
91NiteRida''s Avatar
Car: 1991 Camaro
Hey Gang,
I just got done installing my 305 tbi.I took it out and rebuilt it myself.Its running awesome except for the fact that its not charging.I had the alternator checked out and it checked out good charging 14.6.It was charging fine before i pulled out the engine,now the battery is at 11.6 or 12 volts when the car is running.
Also,when i took my camaro around the block for a test drive,to test out the new mods,i gave it wide open throttle and it didnt kick down..I know i hooked up the kickdown,but i guess its not functioning right.Can anyone help me out with either of my problems?
Old Feb 28, 2004 | 05:27 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Charging Problem and Transmission not kicking down after engine install
Originally posted by 91NiteRida'
Hey Gang,
You may need to adjust your TV cable. There is a tech article on the home page here. Check it out.
Old Feb 28, 2004 | 08:30 PM
Car: 1991 Camaro
Thanks for the help..I'll go adjust it right now....As for the charging problem,i got it fixed
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
