O-Ring for Dipstick Tube?
Old Feb 10, 2001 | 10:41 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Is there any type of o-ring or someting like that for sealing the dipstick tube into the block?
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Feb 10, 2001 | 10:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
RTV is what you use.
Old Feb 10, 2001 | 11:00 PM
Guest
Guest
Posts: n/a
That will work, or you can use a non hardening sealer (thats what I use) or Permatex aviation sealer (my friends favorite, but dont ever try to take it out again).
Old Feb 11, 2001 | 02:34 AM
Pat Hall's Avatar
I've seen o-rings on some dipstick tubes, but like Mkos said, a thin coating of RTV usually works best on small block Chevys.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Feb 11, 2001 | 08:05 AM
ede's Avatar
ede
i use teflon pipe sealer, it is also non hardening.
ICON Motorsports
1st & 3rd
Old Feb 11, 2001 | 02:48 PM
Car: 89 IROC-Z
Engine: 383
Thanks guys
--RPM Racing--
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
NZKnight
Oct 15, 2015 02:47 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
