Bolts for fuel pump block off plate
Old Feb 11, 2001 | 02:50 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Does anyone know the size? Also under the flange for the fuel pump on the block is a hole about 7/8" in diameter. Does this just stay exposed?
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Feb 11, 2001 | 03:02 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
3/8 Coarse for the large bolts, and 1/4 20 for the 2 smaller ones in the block off plate.
Yes, the hole where the fuel pump rod goes through (or used to ) is left alone, the block off plate just covers it, you don't need to do anything to it.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Feb 11, 2001 | 04:04 PM
Car: 89 IROC-Z
Engine: 383
Engineboy do you know how long the bolts are?
Old Feb 11, 2001 | 04:13 PM
Guest
Guest
Posts: n/a
The holes are 3/4" and 1" deep (for the 1/4 and 3/8 respectively) so I would use some 1/2" long bolts and that will be fine.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
