Where can i go to find what type of engine?
Old Feb 27, 2004 | 01:58 PM
F-Bodeee's Avatar
Car: 1991 Pontiac Trans Am
Transmission: Borg Warner T-5
Hi,
i just bought an 87 T/A w/ a 350 carb'd SBC. I got the engine code from it (V0617PJC). I know the first letter is the assembly plant, the 2nd, 3rd, 4th and 5th numbers are the date and i know the 6th number is supposed to be the type (Car or Truck)(C or T) but mine is neither C or T. Where can i find this out? Also what does the JC mean? Thanks
Old Feb 27, 2004 | 10:19 PM
F-Bodeee's Avatar
anybody?
Old Feb 27, 2004 | 11:31 PM
BottlesR4Babies's Avatar
Car: 91 Z28
Engine: 350 TPI H.O.
look up your RPO's in your glove box most likely, using the RPO decoder.
Old Feb 27, 2004 | 11:40 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That number only tells you when, where, and what shift workers cast the block.
You need the actual casting number to know what size engine it is.
www.Mortec.com will help you a lot.
Old Feb 28, 2004 | 12:51 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The last three digits of the stamped code "PJC" tell the story.
Go to http://www.chevymania.com/partsid/ and click on 'suffix codes' - small block, then use the first drop-down menu to find that code, and hit 'GO'. That'll tell you the year, displacement, what is was originally installed in, the stock hp rating, induction type, and RPO code.
Pete
Old Feb 28, 2004 | 01:32 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Look on the back of the engine, where the tranny bellhousing bolts onto the block, drivers side. There is a number there, and thats the number you want. If its a non-original 350, then the last 3 digits are probably "010". It could be something else though.
If its not 010, post the last 3 digits here and someone will tell you what you have.
Old Feb 28, 2004 | 10:36 AM
F-Bodeee's Avatar
thanks, Pete's.....it told me PJC is an 88 Truck 350 w/ 195 HP. Thats exactly wut i was looking for. Thanks
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
