Can someone help me figure out compression ratio
Old Feb 28, 2004 | 09:08 AM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
Hey I have 9.0:1 comp with 76cc heads right now what would it be if I went to a 64cc heads...I am on a tight budget and the pro lightning heads are cheap and all but the vortecs fit my budget better....
Old Feb 28, 2004 | 09:42 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Can't do the math with just that information, but it'll be in the 10.0-10.2 range.
Old Feb 28, 2004 | 09:55 AM
Car: 89 camaro RS
if I was easy on the timing do you think it would run on 93 octane for the street..
Old Feb 28, 2004 | 10:12 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I think 10:1 or so is streetable. Do a search, im sure this has been brought up before.
If it were me, 10.5:1 for cast iron, maybe 11:1 for aluminim is the maximum i would run for compression with 93 octane.
Im goig to be running a larger cam however that will be keeping that compression in check.
Old Feb 28, 2004 | 10:45 AM
Car: 89 camaro RS
i was thinking about using the comp cam 274* extreme energy cam..
Old Feb 28, 2004 | 02:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
the XE274 is a very strong cam. There are several members who run that cam with no problems. Its a milder cam than the one im using. You should be fine.
Old Feb 28, 2004 | 03:11 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You'll be fine on compression. The vortecs will be a nice upgrade.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
