383 Build up
Old Mar 1, 2004 | 06:29 PM
1982Camaro383's Avatar
383 Build up
Question for you guys, I am going to build a 383 setup here next few months for my 1982 Camaro. I want to get about 500hp & 525tq. I am gonna use a 4-bolt main with splayed caps. I am also going to use AFR 195cc heads with rpm air gap intake which hydraulic roller cam, rods and pistons should i use as well as carb. I am looking for a power band from 2000-6500rpm. I am going to be using a th350 trans and soon t56- Viper transmission. I am going to beef up the frame with sub-frame connectors and roll cage in the future as well as suspension upgrade. Car is going to be used for drag racing and havin fun burnin rubber. Any help would be greatly appreciated.
Thanks,
Justin
1982 Camaro
Old Mar 1, 2004 | 06:35 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I just bought a internally balanced kit from this guy, it`s all eagle and was a great price..he`ll basically customize it to what you need. For the price I couldn`t say no
legacepower@aol.com.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
83RDRACR
Mar 26, 2016 08:13 PM
Jorlain
Oct 8, 2015 01:57 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
