Should I get an AFPR???
Old Feb 12, 2001 | 03:10 AM
Dan87IROC-Z's Avatar
My mods are listed below. Take note that I am up high in Colorado at about 5100 feet and there is less air, so should I need one, and if so, what PSI should it be set to?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 12, 2001 | 09:14 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I would do it man. Most people that do that AFPR love the mod. Increase your fuel pressure, but make sure u buy gaskets for the stuff you will be removing and buy a fuel pressure guage for your kinda car so you can see what psi your running.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Feb 12, 2001 | 07:29 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
bump it up a little at a time too. Honestly i'd do it at the track so you can see what PSI your car likes and does the best with. Wouldn't be hard at the track either considering the TPI units have the FPR's to the back of the plenum.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Feb 12, 2001 | 09:07 PM
Vader's Avatar
Dan,
I got mine for 55¢. Best mod for the money I've ever done...
AFPR.pdf
You'll need Adobe Acrobat Reader to view the file.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 12, 2001 | 09:14 PM
james_fearn's Avatar
That's a damn fine write-up Vader. Very nice.
James
1985 Z-28 305 TPI
221,000+ mi., Original Eng.
Old Feb 13, 2001 | 10:07 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Oh yeah vader, well mine's gonna cost a nickel...neener neener.
But i'm gonna be burning proms first, so i will do all my tuning in there. I just want to bump the FP for fun.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
