Where can i find 170 thermostat at Quebec????
Old Feb 12, 2001 | 12:49 PM
stallone's Avatar
Hi guys, after reading a lot of posts, i have decide to go with 170 deg thermostat. So, my problem is that i can find it at quebec city!!!!!!! I have calling UAP napa, ac delco and performance shop, and it not exist here. If someone can help me, i very appreciate. So, you can give me i link to an online shop or a place where i can buy it around where i live.
thanks
trans-am 91 3.08 posi 5.0 lb9 5 speed stock
Old Feb 12, 2001 | 01:36 PM
ihateallmustangs's Avatar
try canadian tire.
Old Feb 12, 2001 | 01:54 PM
stallone's Avatar
no, they dont have it!!!!!
Old Feb 12, 2001 | 05:32 PM
stallone's Avatar
up, nobody have a suggestion????
[This message has been edited by stallone (edited February 12, 2001).]
Old Feb 12, 2001 | 05:44 PM
rondubbs's Avatar
TPIS sells it. you will have to order it through the mail..
Old Feb 12, 2001 | 05:55 PM
i guess thats what u get when u dont lower your flags for trudeau
Old Feb 12, 2001 | 06:01 PM
Macgyver's Avatar
170 is the problem, you can find a 160 or 180 no problem.
I think 170 is too low, just save some bucks and get a 180.
Old Feb 13, 2001 | 10:51 AM
stallone's Avatar
so, which is the best: 160, 170 or 180????
Old Feb 13, 2001 | 11:56 AM
rondubbs's Avatar
isnt there a GM part # for a 170* stat? i know there is.
170 is the best, if you want your car to run at 170 get the stat and a hypertech 176* fan switch.
Old Feb 13, 2001 | 12:08 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I bought my 170 degree stat from Pep Boys. It wasn't for a L98 though and the OD was slightly bigger.
I just attacked it with my Makita grinder and it dropped right in.
I used the TPIS trick of drilling four holes in it since I'd blocked the bypass in the block.
Works like a charm and is really inexpensive too; about $4.00
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Feb 13, 2001 | 02:13 PM
stallone's Avatar
Can you tell me for which car your thermostat was built? With this, i am be able to search at canadian tire store.
Old Feb 13, 2001 | 02:54 PM
Guest
Guest
Posts: n/a
Theres a thermostat for a nissan that is the chevy stat, 170 temp, and has something attached to the bottom of the stat. You could cut that part off and use it. I dont remember what it fit, but I am thinking early 90's 240SX.
Just use a 180. I am thinking 160 is too cold, dont get a good burn in the combustion chamber.
Hotrodboba400
Dec 10, 2019 07:07 PM
383cam
Sep 9, 2015 06:01 AM
IROCZ1989
Sep 4, 2015 11:54 AM
85Special
Sep 3, 2015 04:21 PM
