stalls when taken out of park
Old Mar 2, 2004 | 07:25 PM
irocpower88's Avatar
i got a 350 with a zz4 cam, power plus intake, 750 edelbrock carb and a regular gm hei vacuum advance distributor. i was wondering why when i take it out of park the engine goes to a really low rpm and then stalls. i also hve the stock torque converter with 323 gears any whelp would be seet , thanks
Old Mar 2, 2004 | 07:34 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Has it just started doing this? Have you recently changed something on the engine? I'm thinking maybe timing, but more info could help.
Old Mar 2, 2004 | 09:56 PM
i just finished with a rebuild and it idles pretty good but when i put it in gear it stalls out , if i turn the idle up excessively high it wont stall but i know that cant be the solution
Old Mar 2, 2004 | 10:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Whats your cars idle speed set at when it stalls out and whats it set at to avoid stalling?
Old Mar 3, 2004 | 07:24 AM
its idles at around 8-900 rpm normally but in order for it not to stall i have to set it at like 3000
Old Mar 3, 2004 | 10:46 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Does it have a lopey idle? Whats your vacuum at idle?
Old Mar 3, 2004 | 11:08 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Does it throw any codes?
It may just be a case of a clogged cat or bad fuel fuel filter. It may be you have a lean mixture, try setting it a tad richer.
Old Mar 3, 2004 | 01:30 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Sounds like a vacuum leak.
Old Mar 3, 2004 | 07:36 PM
i'm 99% sure that there is no vacuum leaks, fuel filter is new, but its possible that i have a lean mixture or couldnt also be too rich of a mixture also?
Old Mar 3, 2004 | 07:52 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
What does it do when it stalls? Is it an abrupt stall or does it kinda jerk and surge and then stall?
I imagine a rich mixture stall is possible...but I think it would have to be REAAAAAL rich for that to happen. Ridiculously so. How does it run if you get it moving down the road? Any problems above low speeds? I IMAGINE a very weak ignition could stall an engine under load just like a lack of fuel, etc. might.
Oh and btw....your first post contradicts itself in the distributor. If you have an HEI distributor, you don't have a vacuum advance....you've got electronic advance. Vacuum advance is for non-HEI (one step up from mechanic advance).
This post is getting REALLY long...sorry about that. I'm a little drunk so my thoughts are coming one at a time, so I keep adding paragraphs. You mentioned your converter is stock....how lopey is your cam? Do you have specs on it? A very lopey cam on a stick converter can be tricky to put into gear. The converter will grab so hard at such a low rpm (the converter on these stalls at probably 1200 or less) that it holds the engine back from idling normally and will stall it out. But still, it shouldnt take a 3000 rpm idle to keep the engine from stalling. 3000 rpms equals a neutral drop..... Btw....avoid putting it into gear at 3000 rpms. With a 350's torque, it's a great way to break a good transmission.
Old Mar 3, 2004 | 08:26 PM
then y is there a vacuum port on my distributor? i thought that was for the ignition advance
Old Mar 3, 2004 | 08:30 PM
o yea and it does run for a sec in gear then it dies
Old Mar 3, 2004 | 08:31 PM
Nixon1's Avatar
D'Oh...I forgot, yours is a carbed motor. In an 88. Meaning, not the stock motor. Then you have a vacuum advance distributor, and probably not an HEI distributor. No coil-in-cap distributor correct? Coil mounted somewhere remote....cylindrical coil? And describe 'runs for a second in gear and then dies'... We need precise details here man!
Old Mar 3, 2004 | 09:22 PM
theno1prince's Avatar
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
Are you sure that it takes 3000 rpm not to stall? At that rpm, you are far, far from idle. Not to mention your brakes won't even hold the car with the stock converter. If it is at 3000 rpm, what do the rpm's drop to in gear?
When you set your idle speed, make sure you set your idle with the car in gear. Use the parking brake and wheels chocks. If that checks out, then I would check your initial timing.
Old Mar 3, 2004 | 10:02 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Simple inspection for vac. advance or not. Is there a little metal cone coming out of the side of the distributor? And he says hes using a standard GM HEI unit. Most every GM HEI i have seen is coil-on-cap design.
The specs of the ZZ4 are:
-208/221° @.050
-.474/.510 lift
-112° lobe seperation
Its by no means an "overly-aggressive" cam. and it should pull plenty of vacuum, otherwise GM wouldnt use it in their crates without a warning.
Old Mar 3, 2004 | 10:07 PM
Nixon1's Avatar
Yeah, that's not a crazy cam. Lot of exhaust lift, but not much intake lift...and the duration is wimpy. Should pull plenty of vacuum...maybe 15 Hg's at idle. Brakes will operate pretty close to normally at 15...
Old Mar 3, 2004 | 10:10 PM
Nixon1's Avatar
Ditto. For the V8's anyways. The sixes got remote coils. I'm only suspecting a non-stock distributor because according to his name at least, his car is an 88 and 88's dont come with carbed motors... And if it's a carb, unless its one of those electronic q-jets, it shouldnt have an HEI.
Old Mar 4, 2004 | 12:10 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
HEI's can have vaccum advance, I have 2 of em.. the computer controlled HEI's were stock in most if not all third gens though.. HEI simply refers to any gm dist that doesnt use ignition points..
Old Mar 4, 2004 | 07:42 AM
ok , when i turn the idle upto around 2000 rpm the car will shift into gear and go , but if i turn the idle down to where it should be at around 800- 900, the car will idle really choppy and low like at 400 rpm and when i go to hit the gas to move it stalls out, i hope that is descriptive enough
Old Mar 4, 2004 | 07:46 AM
it is an hei vacuum advance distributor, could it be possible that i have my air/ fuel mixture screws out of wack? i know the timing is at tdc, so it can't be that , it has to be the carburetor . it has a new mechanical holley fuel pump, the old one is out of the tank, could it also be that i used the tpi fuel filter on it instead of a carb one? thanks guys
Old Mar 4, 2004 | 09:30 AM
Nixon1's Avatar
I doubt the fuel filter would make THAT kind of a difference.... By it stalling when you're hitting the gas, it definitely sounds like it's not getting fuel to me. And when you hit the gas, it's letting all that air in and the motor isnt getting the fuel it needs, so it goes super-lean and stalls.
And by your timing, you set it at 0 degrees of advance then? Try upping it until you hear it start pinging (better to do this with the engine under load because it might not ping at, say, 6 degrees with no load, but a loaded 6 degrees might start pinging) , then back it off a little bit...see how it does then.
Old Mar 4, 2004 | 11:12 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
My advice would be to set your timing at 6*-8* base timing, and to hook your vacuum advance can to the passenger side port on the front of the carb (ported vacuum)...
Old Mar 4, 2004 | 11:43 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
How many degrees of timing do you have rght now, while the car in gear? Change that and adjust your idle mixture if you havent already done so.
Old Mar 4, 2004 | 12:54 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yes ...sounds like no advance to me also...HEI is non computer controlled.....had an old IHI scout that I rebuilt the 4 banger in it...perfect idle..put it in gear died......turned out to be a very sticky distributor that was cured with some wd-40...check the vaccuum advance is connected to the carb and distributor as suggested,,,,,
Old Mar 4, 2004 | 02:30 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
My car will idle fine in park and then die when you put it into gear if the idle mixture screws are too lean.
Old Mar 4, 2004 | 09:30 PM
sweet guys thanks for the help ill let you know the results soon, my setup will prolly get me 350 hp with 10:1 compression and 202 160 valve heads and a perdormer eps intake dont ya think? probablay gonna hook up a msd 6a soon.
Old Mar 6, 2004 | 01:11 AM
Nixon1's Avatar
350 at the engine is definitely VERY possible. 350 at the wheels is a tad trickier...but you might be close to it. Maybe 325+
Old Mar 6, 2004 | 01:21 AM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
Do you have a locking torque converter? If so, might be the lockup switch.
Old Mar 6, 2004 | 01:52 AM
Nixon1's Avatar
He said he's got the stock torque converter... And I know what youre thinking.....but a converter lockup, even if it's broken and STAYS locked....it CANNOT lock in 1st gear. 2nd and up, but it won't lock in first.
Old Mar 6, 2004 | 06:57 AM
thirdgen88's Avatar
Car: 1995 Corvette
Correct, there is no fluid routed to the lockup solenoid until second gear... even if it was stuck shut, it shouldn't lock up before second...
Old Mar 6, 2004 | 07:35 AM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
my friends camaro does the same thing but i am blameing it on the stall we adjusted everything and looked over everything like 100Xs. atleast your brakes r still good, my firends car sucks at brakeing at low speeds, will never ever stop on a dime, but its no to bad up high. so ya like i said we r blameng the stall, when u fix this problem please let us no what was the problem.\
good luck!
Old Mar 6, 2004 | 02:13 PM
Nixon1's Avatar
Low-rpm braking issues sounds like poor engine vacuum due to a high-lift or high overlap cam, or vacuum leak, or a faulty power booster.
Old Mar 6, 2004 | 09:11 PM
thirdgen88's Avatar
Car: 1995 Corvette
Definately has NOTHING to do with the torque converter...
Old Mar 6, 2004 | 09:20 PM
Nixon1's Avatar
Lol...yeah, if the converter is stuck in lockup...you'll notice VERY quickly. It's like shifting into 3rd gear immediately after shifting into 2nd. Except you haven't hit 3rd yet. And you'll hear grinding noises, etc. sometimes on decelerations and turns. I know. I wired a lockup switch and accidentally left it on one time.
Old Mar 6, 2004 | 09:35 PM
thirdgen88's Avatar
Car: 1995 Corvette
I was actually referring to the other guys brakes not working being related to the torque converter (Nope)... But yes, the converter lockup being stuck on would be about as unnoticable as a 747 parked in your driveway...
Old Mar 7, 2004 | 08:40 AM
Well,try unplugging your vac advance, set your timing to 4* , turn your idle down so it allmost dies, then turn your idle mixture screws out untill your idle is where you want it.
Old Mar 8, 2004 | 09:16 AM
Engine: 406
irocpower88
sure would be nice if you would give us an update...
Old Mar 8, 2004 | 10:49 AM
Yeah,Don't leave us hangin
Old Mar 8, 2004 | 01:08 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
Hookup a vacuum gauge to that carb and tune for highest vacuum reading.
Old Mar 8, 2004 | 01:11 PM
jpk91rs's Avatar
BTW, I have seen a lockup convertor installed on a non lockup 700R4 and it would lock up intermittently and stall the vehicle. The fluid could be routed to the lockup clutch in the convertor at any time. Don't rule this possibility out.
Old Mar 9, 2004 | 10:53 AM
well got the motor running good, but now i have too low of a stall on my torque converter. i knew i should have got a new one. thanks for the help guys
Old Mar 9, 2004 | 11:06 AM
  #42
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Irocpower88 said: "I just finished with a rebuild...". I'm in the same "circle": engine rebuild - too much air into the motor - engines dies at idle in gear. What happens?...
Denis V.
Old Mar 9, 2004 | 07:53 PM
  #43
Glad to here What was the problem?
Old Mar 9, 2004 | 08:47 PM
  #44
Nixon1's Avatar
Lol, stock converters on cammed cars suck SO bad. I've got a stock converter behind a cam with 220/220 duration at .050 and .498/.498 lift...it sucks. At low speeds in higher gears, the engine starts to lope and "bucks" the transmission. Thunk thunk thunk thunk---downshift.
Whenever ya get one....stall it to about 500 rpms before your powerband. If your car gets a full-solid powerband pull at 3000, then stall it at 2500. You dont wanna stall it INTO the powerband, but right before it to give the engine time to come into it. And a stall too far below it is a waste.
Old Mar 9, 2004 | 09:29 PM
  #45
the timing was off and i swiched the 750 edel to a 600 edel and that seems to match a lot better, im seriosly thinking about ditchin the 700r for a wc t-5, what you guys think of that?
Old Mar 10, 2004 | 06:20 AM
  #46
Denis.V's Avatar
Axle/Gears: No idea
Yes, It's as Nixon describes: At low speed, tranny is doing ....ThumP! - downshift...
(Mmm, I can see a Ford in the Nixon's post....)
Old Mar 10, 2004 | 04:31 PM
  #47
Nixon1's Avatar
Lol, yeah, that's the Rustang I had to sell the Camaro to get. One engine and a lot of money later, it's in the 13's. Still needs a tranny though.
junior419
Apr 7, 2025 11:35 AM
RedLeader289
May 28, 2019 01:47 PM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
