Is a '94 Chevy 350 truck block roller?
Old Feb 14, 2001 | 12:43 AM
Erik formula L98's Avatar
A friend of mine bought a complete motor off a '94 chevy pickup. Is this a roller block or just a regular hydraulic? Thanks.
Erik '89 Formula 350 TPI
13.96 @ 97 on motor
12.63 @ 111 w/NOS
http://www.geocities.com/formulal98/
Old Feb 14, 2001 | 01:11 AM
GOLD85's Avatar
roller
Old Feb 14, 2001 | 02:01 AM
SCRA rules!'s Avatar
I think the roller cams didn't start until '96 with the vortec heads. My '93 350 truck was not a roller cam.
'93 2wd truck
408 sb, vortecs, 454 TBI, Comp Cam, dual exhaust
Old Feb 14, 2001 | 07:12 AM
93ND500's Avatar
Yep, it's a roller block. Propably didn't come with a roller cam though. The provisions are there, GM just did not use them.
1993 C1500 Indy 500 Edition
1992 TA TPI setup
Stock motor, new one being built now.
www.geocities.com/wsleigh
Old Feb 14, 2001 | 09:06 AM
Hey thanks for the replies dudes. He's gonna fix up this block with all the hardcore parts then put it into his '92 Z-28 with the superram.
13.96 @ 97 on motor
12.63 @ 111 w/NOS
Old Feb 14, 2001 | 02:22 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by 93ND500:
</font>
This is correct. You might have to drill and tap the holes for the "spider" that holds the lifters down, but the provisions are there to use a roller cam.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 14, 2001 | 03:08 PM
Blade's Avatar
That's what I thought too with 91 350 block. I had the holes tapped for the spider, but when I went to put the cam in... it wouldnt go all the way in the block, plus the block doesnt have the provisions for the cam retention plate. That kinda tells me it calls for a regular cam. I'd say get a full roller block that has the provisions already there if you want to use a roller cam.
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old Feb 14, 2001 | 03:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Or just get the legacy style roller cam and don't worry about the factory's demonic hallucination of a roller system.
ICON Motorsports
jhawkeye
May 25, 2022 06:33 PM
junkcltr
Aug 2, 2019 11:12 PM
NinjaNife
Aug 23, 2015 11:49 AM
anesthes
Aug 8, 2015 09:37 PM
