Will Stock Springs in TrickFlow 23's Support a ZZ4-1.6RR?
Old Feb 13, 2001 | 04:56 PM
Mike92's Avatar
The specs in Summit are up to .500" lift and the ZZ4 cam is .510", I guess not huh. I wold like to use this cam because it's cheaper than most othere roller cams and good power. Anyone know of an inexpensive roller cam that gives 1500-5500 power?
Old Feb 13, 2001 | 05:42 PM
The ODB's Avatar
Yes
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
Old Feb 13, 2001 | 06:05 PM
ede's Avatar
ede
i'd replace the valve springs. you won't find a roller under 400 dollars that i know of.
ICON Motorsports
1st & 3rd
Old Feb 15, 2001 | 12:24 AM
Dan W's Avatar
I paid about $200 for my lunati roller cam. Cam only, not kit.
http://www.holley.com/HiOctn/ProdLin...CC/Chevy4.html
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter
350 .060 over with forged 1 pc rms crank, and forged TRW pistons, 9.5:1 cr
Factory GM heads Pocket ported, 2.02/1.60 valves, back cut
Lunati roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
Edelbrock Performer EGR intake, Edelbrock TES and 3" cat
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
