sometimes car won't start, please help!
Old Feb 14, 2001 | 11:30 AM
91fbird's Avatar
I have a 91 firebird and sometimes I go to turn the key and... nothing. But the "security" light comes on. Is this some factory anti-theft system? If so, what triggers it? And how can I disable it? If I wait a while, I go to start it and it fires right up. Thanks in advance.
Old Feb 14, 2001 | 12:52 PM
Camaros4_life's Avatar
Since you say its a 91 then it should be equiped wih vats, the little stone on the key... Make sure your using that and not a copy. I know that you can dissable that vats system but I don't know how.
Old Feb 14, 2001 | 01:10 PM
Steve89GTA's Avatar
Clean your key with some WD or Liquid Wrench. The contact in the middle of the key is a resistor value that the computer must 'read' to enable the ignition system. Spray some wd in the ignition keyspace as well. I was surprised at how much gunk came out of there. Feels brand new after you clean it up though...
89 GTA G92
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
Crane Ignition
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Feb 14, 2001 | 01:18 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
DO NOT spray WD-40 in your ignition or door lock cylinders, unless you want to mess 'em up eventually. Use that graphite stuff that's made for that...
Now, my experience with your type of problem turned out to be corroded/dirty terminals on the starter and battery. My car did the same thing for 3 or 4 months, then I figured it out one (by luck, I guess) and disconnected everything on the starter, solenoid, and battery. I cleaned them up using the wire brush on my dremel, and doing some by hand, but have not had a problem since - been about 5 months now...
KAM
Old Feb 15, 2001 | 01:44 PM
91fbird's Avatar
Thanks guys. I will try all these suggestions.
Old Feb 15, 2001 | 01:57 PM
jmon92conv's Avatar
I go through the same problem on my 92Z, sometimes it just won't do anything. It is the VATS i nmy case. I just let it set for a little bit 15-20 seconds with the key out, and try it. It usually works.
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
