Service/Check Engine light comes on after wide open throttle
Old Mar 5, 2004 | 08:46 PM
91NiteRida''s Avatar
Car: 1991 Camaro
Hi,
I have a 91 camaro with a 305 tbi..I just recently rebuilt my engine and got all the bugs out of it....Only problem i have now is the Check/Service Engine light comes on after i give it wide open throttle.When im cruising,it doesnt come up or show up on the dash until i mash on the gas....Once its on,the car doesnt drive or sound any different just gets annoying seeing the light on.If i restart the car,it doesnt show back up....Can someone help me out?My car running too rich causing it to show up?O2 sensor?All and any info is greatly appreciated
Old Mar 5, 2004 | 09:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked to see if any trouble codes are stored in the computer and if there are, what are they?
Old Mar 5, 2004 | 10:46 PM
Car: 1991 Camaro
No i havent pulled any codes.I have no idea on how to
Old Mar 6, 2004 | 12:15 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Look under the dash by your right knee and you will see a 12 pin connector there. It might have a cover over it saying diagnostics. With the key in the "OFF" position, take a paper clip and jumper the top two pins on the right hand side (pins "A" & "B"). Turn the key to the "ON" position but don't start the engine. The service engine soon light will come on for a second and then start to flash the codes. It will flash once, pause and then flash twice more for code 12. It will do this three times and then start to flash any other codes it has stored in the computer. It will flash each one three times as it goes through them. After the last trouble code has flashed, it will repeat the cycle again. Code 12 is a normal code, also if the fans come on this is also normal. After you have gotten all the codes, turn the key to "OFF" and remove the paper clip.
Old Mar 6, 2004 | 01:55 AM
Car: 1991 Camaro
Thanks for the help Trickster...I'll be doing it first thing in the morning
Old Sep 20, 2009 | 06:40 PM
Garth Knight's Avatar
Car: Firebird
Engine: 3.1 V6
Re: Service/Check Engine light comes on after wide open throttle
Hello, I've the exact same problem. I don't know the ECM code. Can anyone give me any suggestion?
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
