will not run
Old Mar 6, 2004 | 05:39 PM
51 chevy's Avatar
will not run
hello i just swapped a 1227730 ecu to a 1227727 and now the engine will not run i have a stock aujp chip and a modified chip bolth have vats removed and the motor ran before the swap.i get spark at all the plugs and i am getting fuel to inj. i have checked the wireing many times and i even tried a different 7727 ?the #2 cylinder fires up about every other time, none of the others do anything. ive also moved the timing forward and back with little change.i also got a new ignition control module,no change.the ecu is not giving any trouble codes and i hooked up aldl monitor and nothing looks wrong?any ideas would be great...thanks.
Old Mar 6, 2004 | 08:57 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
why did you swap the ecu if the engine was running?
Old Mar 6, 2004 | 09:33 PM
51 chevy's Avatar
because 7727 is water proof!!!!!!!!!
Old Mar 6, 2004 | 09:40 PM
Kontrax's Avatar
Car: 86 Camaro
water proof? your talkin under the hood here? im thinking of something else if your talking under the hood..... i dont see why there would be something like that under the hood if it wast water proof. you got me dude
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
