305 TPI cams, and emissions.
Old Feb 15, 2001 | 09:22 PM
3.1 firebird's Avatar
I might get a 90 305 TPI with the weaker cam, I was thinking about getting the better cam and swapping it in. My question is.......are the emissions standards for each cam different then the other?
Old Feb 15, 2001 | 09:42 PM
Vader's Avatar
3.1,
You can install a non-emissions-legal camshaft in any engine you want. Where you drive it is entirely up to you, but it won't be legal to drive on the street.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 15, 2001 | 10:06 PM
MrJ's Avatar
MrJ
no, but if it's a 90 305 TPI, chances are overwhelmingly good that it has the better cam already. The 'peanut cam' stuff is just a myth when it comes to the 90-92 cars.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Feb 15, 2001 | 10:22 PM
I was reading on the tech section where if the 305 TPI has a tach that redlines at 5K its the peanut cam, if t reds at 5500 its the good cam.
Old Feb 15, 2001 | 10:49 PM
MrJ's Avatar
MrJ
it's wrong. it needs to be updated.
Old Feb 15, 2001 | 11:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, the emissions are the same. And there are hundreds of cams out there that will pass emissions, even tho they arent labeled as being smog-legal. Who knows but you what kinda cam is in your car, as long as it passes clean out the tailpipe.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
