Has anyone moved the charcoal canister to under the car?
Old Mar 7, 2004 | 01:48 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I remember seeing a picture on this board of a 4’th gen gas tank with the charcoal canister mounted right on top of it. I was wondering if anyone has attempted putting a 4’th gen charcoal canister under there car or tried moving the 3’rd gen canister out of the engine bay.
I am trying to clean up some clutter in the engine compartment but I don’t want to get rid of it.
Old Mar 7, 2004 | 08:03 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Along with just about anything else on the car... it's not finished yet but, here's a pic. anyways..
Attached Thumbnails Has anyone moved the charcoal canister to under the car?-evap.jpg
Old Apr 24, 2004 | 03:02 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
how did you guys do this? i haven't got a response from the thread I started. did you tap into the vent line, and then run a new vacuum, and plug parts of the control valve? I'm fumbling in the dark, guys... help a bro out.
Old Apr 24, 2004 | 03:11 PM
Car: 1982 Trans Am
Engine: 383 chevy
also, is it ok to turn the canister sideways? or is this a bad idea?
Old Apr 24, 2004 | 08:32 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
The cannister must remain in the vertical position.
I'm relocating mine to the area behind the drivers side headlight under the battery. I'll be fabbing up a bracket to solidly mount it later this spring after I get the front suspension back together.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
