coolant leak
Old Mar 7, 2004 | 07:52 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
coolant leak
Is a heater core on a 92 RS hard to change and is it exspensive. I have a coolant leak somewhere and I think I traced it to the heater core becuase my carpet on the passenger side is allways wet and if I have my windows down I smell coolant really strong. im not a 100% sure and dont even know where the heater core is on my car but in alot of cars its in that general area.
Old Mar 7, 2004 | 07:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yea that sounds like your heater core. You have to take your whole dash apart and it is a pain. There was a good write up in a thread that was posted not to long ago. I bet a quick search would find it for you.
Old Mar 7, 2004 | 09:44 PM
deb92rs's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Yes, its hard to change and yes its expense if you pay someone else. Just disconnect/plug the hose in the engine bay that goes into the firewall. Most FL people do this instead of replacing it. Really, how often do you use the heat? I'm lucky in that my doesn't work, but it doesn't leak either so I've just left it alone. My sister had to disconnect the hose on hers due to the same leak you are discribing.
Old Mar 8, 2004 | 09:31 AM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/t...atercore.shtml
some have just removed the bottom panel and went for it instead of removing the whole dash. just pull the dash pad and see if u can do it that way instead of wasting all the time taking apart the dash.
Old Mar 8, 2004 | 10:05 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Transmission: 4spd
ok thanx
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
ULTM8Z
Oct 2, 2015 01:25 PM
