knock sensor sends signals but no code?
Old Mar 8, 2004 | 12:39 AM
rockstar's Avatar
Car: 1991 trans am gta
Engine: 350 tpi
ok first off here's all my info:
91 pontiac trans am gta
350 TPI with some mods, basically bolt ons, (runners, headers, exhaust, MSD wires + coil + box, etc...)
anyway so heres my problem:
I hooked up my car to a OBD1 scanner to check how my car was running. My car wasn't throwing any codes but when i was looking at the real time operation status my knock sensor was sending some signals, so i decided to test drive my car with the scanner connected and sure enough when i put my foot on the gas the timing started to retard, it retarted up to 15 degrees, and sometimes jumped to 20 degrees when i floored it, but the time retard went strait to 0 when i let my foot of the gas. ive tried listening and i dont hear any audible knock so im in question to as if the signal is real. any suggestions on what it could be if it is a false knock, and if it is a real knock why isnt my engine throwing any codes?
thanks for the replys in advance, ill be happy to answer any questions you might have.
rockstar
Old Mar 8, 2004 | 05:51 AM
ede's Avatar
ede
i ithnk what is happening is the knock senser is picking up know and sending a signal to the est to chage timing and not setting a code in the ecm.
Chuck84TA
Jul 15, 2016 09:05 PM
Caspar
Jun 19, 2016 11:19 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
