Starter shim problem
Old Mar 8, 2004 | 05:31 PM
justanothercar's Avatar
Car: 85 z28
Engine: 355
I have a 85 z28 I converted to standard,it has a the t-5 out of an 84 and a 350 motor,i bought the starter for the 84 camaro beacus ethe old 350 starter did not fit in the t-5 case.
The bendex will Not engage the flywheel i cant get it close enough we have tried alot of shims in dif combonations,and it ended up with the end of the starter breaking off,anyone have any ideas?
Old Mar 8, 2004 | 05:54 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
try an LT1 or ministarter, and see if this helps.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
