problem with corvette alluminu heads on 305 TPI ,HELP!!!!
Old Feb 17, 2001 | 02:22 PM
vortech305's Avatar
I bought a set of 88' corvette alluminum heads for my 88' 305 TPI motor. The spark plugs have been used with ani-sieze but what r the torque specs. for the spark plugs and at what gap do i need to use. Should i use the original gap size for the 305 cast iron heads or for the corvette heads please write info.
92' camaro
Edelbrock intake,ported plennum,ported corvette alluminum heads accel cam,52mm throttle bodie, SLP runners,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods msd 8.5 mm wires hypertech coil and plug, Edelbrock TES headers, free flowing catalytic converter and a 3 ich force II flowmaster exhaust system.
Soon to come!!!
Procharger system 12lbs o boost.
Old Feb 17, 2001 | 02:32 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Since it looks like you have a good ignition in your car, I imagine that you can open up the gap to .045 to .055 inches. As for the question of which plug to use, that really depends on how it's running. Once you stray from stock, the rules all change. I'd say stick with the Corvette spec. One thing you should remember: You'll want to use a .015" steel head gasket from GM for the 305 TPI application. if you pick a thicker gasket, you'll lose compression ratio. The aluminum head will enable you to crank up the compression ratio as high as you can. With a 58cc chamber and a .025 deck height, you'll be sitting at 9.6:1 compression ratio when you use the steel head gasket. The aluminum head can easily support a 10:1 c.r. in that 305 as long as you use 92 octane fuel.
I don't know what the torque specs are. In the 18 years of fooling around with cars, I've always just cinched them down until they make contact, then give them another 15 - 30 degrees. I'd estimate about 15 ft.lbs of torque, max. I've never lost one or busted one off!
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
[This message has been edited by ws6transam (edited February 17, 2001).]
Old Mar 3, 2002 | 12:45 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
torque specs are 22lbft on plugs with a gasket seat (flat mating surface) and 15lbft on motorseat (beveled mating surface) plugs. I think most iron heads use the motorseat plugs but my aluminum L98 heads use gasket seats.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
