Car Wont Start!
Old Mar 9, 2004 | 06:51 PM
88 Formula 355's Avatar
Car: 1991 Z28 Camaro
Engine: 355 Solid Roller
Transmission: Turbo 400
Car Wont Start!
Ok so lately my car has been acting a little weird, it was like I could be driving it and like if I got on it sometimes it would like die out and kill itself and it wouldnt crank and crank and not start, other times I could just be driving and it die and have the same cranking problem. So today I get in my car go to work and get ready to leave for lunch, my car cranks and it will not for anything. Let it set try to start it to drive it home at quiting time and it starts and runs awesome like usual. Then a friend of mine comes over to tell me about the drag strip finaly reopening Friday I tell him about my car, go to start it and it wont hit for nothing??? Why in the hell will it run perfect one moment and then not again...
Old Mar 9, 2004 | 07:18 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
it sounds like you have a spark problem. Change your plugs, cap, rotor, coil and wires. If that doesn't fix it pull your distributor and check it for rust to see if it is affecting your spark. Also, what is the temperature where you are b/c this is very similar to a problem I had with my 85.
Old Mar 9, 2004 | 07:33 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yes . sounds like the pick-up coil to me..I had the same symptoms when mine went
Old Mar 9, 2004 | 08:06 PM
The engine has brand new plugs, wires, cap, electronic super coil, and Hi-6 fireball ignition. the temperature just suddenly dropped today to like 30 degrees here lately it's been like 60's
Old Mar 9, 2004 | 09:11 PM
The more and more I think about it, I've got myself to believing it is the pickup coil. I called and got one ordered it'll be in in the morning so I guess we'll find out if that's it. (he he I really hope it is becuase there is a new ***** in town that really needs to be put in his place, especialy with the track opening friday)
Old Mar 9, 2004 | 09:49 PM
Engine: 406
Real easy to replace...you have to pull the distributor.. punch the roll pin out of the shaft at the bottom . All the rest will come apart. the shaft will just pull out of the housing. watrch for any O-rings.
Hope this is the problem its an easy fix. Be sure to mark your rotor for timing reference
Old Mar 10, 2004 | 07:47 AM
Ok so now I get up this morning getting ready to get in the truck to leave as I walk by my car I get curious, jump in turn the key, starts right up I didnt take it out and drive it becuase I dont feel like it sitting anywhere again but I revved it up a little and at about 3000 rpms it had a little miss but it was constant so I'm hoping that maybe it is that pickup coil and it'll fix everything...
Old Mar 10, 2004 | 07:12 PM
Just got finished changing the pickup coil along with the cap and rotor. Thanks for all the help it seems to be running just as bad *** as ever if not better
Old Mar 10, 2004 | 10:40 PM
Engine: 406
Glad to have helped...once in a while I get lucky...
Old Mar 10, 2004 | 10:53 PM
Annihilator's Avatar
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
Prolly coil, my friends and i had the same problem last night with his chevelle. Ran fine one time, then ****ty the other. We replaced his new accel coil with an 80's GM one and the car ran mint.
Old Mar 11, 2004 | 12:22 AM
Engine: 406
Old Mar 11, 2004 | 11:33 PM
whoooooooooo here we go again driving home from work today and outta no where, the peice of **** dies, I mean no prior miss, nothing just dies. So I push it out of the way walk home, ONCE AGAIN and go back 30 minutes later it cranks once then hits drive it home, I pulled it in and just revved it up a little bit to check for a miss held it at like 2 grand and it had a ****ty miss and then just cut out again and wouldnt hit???
Old Mar 12, 2004 | 06:00 PM
Engine: 406
Now this sucks,,,,,have you change the ignition module yet? Just about thhe only thing not on your list,,
Old Mar 12, 2004 | 07:19 PM
Yea that ignition module was the only thing I didnt change, however this morning I figured that that had to be the cause of my problem so I went ahead and ordered a new Holley Annihilator one and hopefully this will fix my problem.. As soon as I get it in and running I'll make sure and post the outcome....
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
