Help, busted tranny mount
Old Feb 16, 2001 | 12:14 PM
billyde's Avatar
Well I am pretty sure my tranny mount is shot on my 700R4, it has the symptoms. IF it is, is replacing it something I can do in the driveway? I mean is it just a questions of supporting the trans with a jack and unbolting the thing?? Thanks.
1984 Camaro Z-28 LG-4
Q-Jet, dual snorkel air intake, underdrive crank pulley, Hypertech Street chip, SLP y-pipe and 3" cat back with hi-flow converter, Edelbrock Performer intake,Accel ignition. Running better now.
Old Feb 16, 2001 | 12:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You got it. Jack the trans with a piece of wood placed across the fluid pan. Place the wood so it goes from "left to right" not "front to back". You don't need to raise it much, either.
Remember your steel bolts are going into an aluminum trans- don't overtighten them or you'll strip the aluminum. I think torque spec for the mount-to-trans is 30 ft/lbs- Can someone please check me on that?
You can also search for info on this in the "Transmissions & Drivetrain" message board.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 16, 2001 | 12:52 PM
ede's Avatar
ede
buy a ES poly mount, they're pretty much bullet proof
ICON Motorsports
1st & 3rd
Old Feb 16, 2001 | 01:05 PM
R.O.B.'s Avatar
Take ede's advice, I went through 2 mounts already, one was the stock one, the other was a Corvette one.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 16, 2001 | 01:48 PM
billyde's Avatar
Thanks alot, appreciate the quick response.
Old Feb 16, 2001 | 04:12 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I agree. The Energy suspension mount is awesome. I kept going through mounts until I got that. My engine mounts were worn too though and it was putting more stress on the trans mount.
'89 Formula 383 TPI
Old Feb 16, 2001 | 10:51 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Loc-tite the bolts going into the tranny. Mine worked loose a couple times till I did.
Old Feb 17, 2001 | 09:51 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
yup energy poly mounts definately
Old Feb 17, 2001 | 06:45 PM
jeff88convertible's Avatar
I guess I will also say energy-suspension mount is the best....I have it on mine and I havent had a problem. Even if you break it there is a safety feature that will not let your transmission go crazy. I remember when my mount went the cat conv. would hit the floorboards! remember this, trans fluid is not kind to rubber it will wear it.
Old Feb 17, 2001 | 06:46 PM
88 camaro rs convetible 92 rims / flowmaster/ hypertech chip/ 3.73 gears/tbi spacer/open elemnt/hollowed cat/shift kit corvette servo/k&n filters/holley tbi unit/NITRO FOGGER /VORTECH HEADS WITH GM INTAKE/future mods 350 with 400 crank/sub frame connectors ....................favorite quote " I WILL SMOKE YOU BECAUSE YOU HAVE 305" SAME GUY LATER SAYS "ARE YOU SURE THATS A 305 BECAUSE YOU JUST SMOKED ME" *************************Check out www.camaroheaven.com for hard to find parts location new hamshire
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
