Gear Drive
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
Gear Drive
I recently got a great deal on a Pete Jackson gear drive I am planning to replace my timing chain set up with this unit. However I have heard that gear drives cause problems with fuel-injected engines (knock sensor noise) if this is true is there anything I can do about it? Or should I stay with a chain?
that sounds promising :hail:
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
You can make your own "quiet" gear drive by drilling a 1/16 hole in about every second or third valley between the teeth on the cam gear and crank gear. Cuts down on false knock problems by letting the air escape, which decreases the whine.
