more aluminum driveshaft questions
i keep hearing that the 4th gen drive shafts WONT work...then on the other hand people here say it WILL work...
what would be the better one to use....the LS1 3.0 drive shaft im assuming......
but what defines the LS1 drive shaft from looking at a pic.....i cant tell a difference ....ugh
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if
it
is
a
fbody
driveshaft
for
any
1984 - 2002
fbody
it
will
work
in
any
other
1984-02
fbody.
the only diffrent length ones were the 82s and some 83s that came with diffrent trans then the 700R4, T5, T56 or the electric shifted auto whos name i can never remember.
and if you get a driveshaft loop, keep in mind that the LS1 alum one is wider.
it
is
a
fbody
driveshaft
for
any
1984 - 2002
fbody
it
will
work
in
any
other
1984-02
fbody.
ambainb
Apr 25, 2016 09:21 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
