timing marker missing / failed visual emissions
Old Mar 10, 2004 | 03:11 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
welp, failed emissions. all the numbers were ok, but visual failed due to "missing timing marker".
im not sure where to start on this one, ive never set the timing before even. prob cause i couldnt, lol...
is this a piece i could get from the boneyard? tho v8 is usually tough to find there...
could i put it on myself?
help?
Old Mar 10, 2004 | 03:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: timing marker missing / failed visual emissions
help?
They failed you because of that!!!!!! What has our society come to. Anyways, the stock tab is only spot welded on and can fall off. it is on your timing cover and is hard to see. You have to look over and down over your water pump to see it. Make sure it is there. That is not just an easy 5 minute fix.
Old Mar 10, 2004 | 03:24 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
Re: Re: timing marker missing / failed visual emissions
that is about a load of....
Old Mar 10, 2004 | 05:46 PM
Diggler86's Avatar
Car: 86 TA
awww crap welded! anyone have a pic so i know what to look for. thnx.
where would i get a new one? i mean, do the dealer even sell it if its a weld on piece? or is it a generic piece i can get from pep boys.
Old Mar 10, 2004 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Perhaps Herr Inspektor didn't know where to look for it.
You have to look straight down between the water pump legs. If he was looking for it at 2 o'clock where Chevy used to put it, he won't see anything.
Old Mar 10, 2004 | 07:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You'll have to get a stock timing cover with the thing welded on, no real way around it.
I used to get alot of stuff like that at Ecology Auto Parts in Oceanside, right across the highway from the Oceanside Airport.
89GTAOz
May 16, 2020 09:31 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 17, 2015 02:52 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
