TPI on a ZZ4
Old Mar 10, 2004 | 09:45 PM
Verviticas's Avatar
Engine: L98 5.7
TPI on a ZZ4
Tpi on a ZZ4. Would this be okay? or is the cam and all just not upto it and i should leave it carbed??
Old Mar 11, 2004 | 10:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The TPI isn't up to it.
But, it can be made so. Shorter larger runners, ported plenum & base, adjustable fuel pressure reg. Custom PROM burning very helpful.
Whether you should stay TPI or go carbed depends mostly on your intended use and expected results. I have a bud who did the TPI/ZZ3 thing several years ago, started as a 90 RS, but he really went over the top: ZZ9 cam, CNC ported heads, zero decked block, Big Mouth Vette base (for EGR purposes) & runners, extrude honed the plenum, runners, base & heads together, etc. A lot of bucks, but he wanted an emissions-legal runner. He got it - fast pass during emissions testing, and 13-flat in the 1/4 NA. Would probably be faster, but so far he's just running hand ported factory manifolds, still working on the headers.
Old Mar 11, 2004 | 11:07 AM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
Stock TPI would work, but poorly. Some sort of upgraded TPI would be fine
lt500r55
Sep 1, 2021 01:30 PM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
italiano67
Aug 31, 2015 06:04 PM
Sanjay
Aug 12, 2015 03:41 PM
