305 engine install back problem.
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi i just put back my rebuilt engine in my t/a and there is some problems that appears. the knock sensor connector is hiding somewere in the engine bay but i dont find it anymore, from where the wire is soppose to go out?and the vaccum of the cruise controle where it should be connected...and there is 2 connector left in the front a green and a white dont remenber if was connected to A.I.R.... and is there a place where i can buy the connector separately than the complete circuit at deeler because they dont sell them.
Transmission: 4L80E/4L80E
You mean you labeled all that stuff as you took it apart, and now can't find it?
Okay, had to give a poke about that. (Lesson to those taking their engine out - label everything as you disassemble.)
This isn't an Engine Swap topic, so moving to Tech where it belongs...
Car: 1989 C4
Axle/Gears: 307
What are these lables you speak of? Actually I never had much use for them since if theres a senor theres a wire some where.
The knock sensore wire if I remember correctly comes from the passenger side near the battery. It should be on the same wire harnes as the smog pump sensors.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
