Jegs A/C Compressor... Will it fit?
Old Mar 11, 2004 | 08:01 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Alright buddy, I was just going through my jegs catalogue and all the sudden I saw a jegs brand A/C compressor for pretty cheap prices. Considering what you get. Here’s what I saw,
Now it is made for v-belt I already made sure of that, but will it bolt up to the existing brackets?
See these as jegs page,
http://www.jegs.com/cgi-bin/ncommerc...93&prmenbr=361
Thanks,
Shane
Old Mar 11, 2004 | 08:02 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
also what would i have to do to covert to R-134? I need new hoses and what else?
Also can you please give me the part number for the hoses and anything/everything else i will need.
Thank a bunch,
Shane
Old Mar 11, 2004 | 08:10 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
it pretty much says that it is meant to be used with R-134a, does that mean i cant use regualr R-12, or since i gotta replace all hoses should i just go ahead and covert?
Shane
Old Mar 11, 2004 | 08:18 PM
Morley's Avatar
That looks to be an old style axial compressor, so , no it won't just bolt right up to your brackets.
To change to R134 you need to change the receiver/dryer, hoses will be ok if they don't leak. Also change the metering orafice tube.
Check here https://www.thirdgen.org/newdesign/t...trofitac.shtml
Old Mar 11, 2004 | 10:28 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
You don't have to change anything to go to 134a if your parts are in good working condition. The only thing I changed was my compressor because it had burned up. Been cold for 2 years now. All the other parts are from 1984. Nothing was touched until that time.
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
