No o-ring gruve on valve, should i still use them??
Old Mar 11, 2004 | 09:50 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I am assembling a set of heads and the stainless steal valves i got do not have the groves for the o-rings should I still put them on the valve or not?
I curently have 12511890 valve seal kit
Old Mar 11, 2004 | 10:03 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Would it be okay just to use 16 of these seals for intake and exhaust without the o ring? Would that solve the problem?
http://www.gmpartsdirect.com/perform...CATID=749.html
Attached Thumbnails No o-ring gruve on valve, should i still use them??-996.gif
Old Mar 12, 2004 | 12:34 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
anyone???
Old Mar 12, 2004 | 04:57 AM
ede's Avatar
ede
if you use umbrella or positive seals it wouldn't matter if you had the groove for o ring seals or not.
Old Mar 12, 2004 | 08:06 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I heave heard that it is not safe to use positive seals on the exhaust because it doesn't allow enough oil to get into the guide. Is it safe to use these seals on exhaust valves?
Old Mar 12, 2004 | 09:50 AM
ede's Avatar
ede
don't know if it's safe or not but fel pro among others makes seals for exhaust valves and i've used them on just about every head i've had apart.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
BOOT77
Sep 16, 2015 08:37 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
BOOT77
Sep 5, 2015 03:55 PM
