paper clip trick
Old Mar 12, 2004 | 01:42 PM
pontiacpower350's Avatar
Car: 89 Firebird Formula 350
Engine: TPI 350
paper clip trick
I hear all the time about using paper clips to bring up codes. What do you do? Thanks for any help you can give me.
Old Mar 12, 2004 | 01:45 PM
CamaroDriver's Avatar
It's on the home page under "FAQ"
Old Mar 12, 2004 | 02:16 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Turn the car off, take a paper clip, piece of wire, whatever you want and jump the 2 hole things in the upper right hand corner of the connector. Then turn the ignition to on but don't start the car. You get code 12 three times then any problem codes three times each. Do a search, there is even a diagram to show you what the upper right hand corner is
Although I think ive heard of useing the upper and lower right connectors on some cars.
Old Mar 12, 2004 | 09:43 PM
3rdgenstm's Avatar
Car: ‘92 Z28
Be careful, there are different positions for different years. I think 90-92 are different than the rest. I jump mine between #5 and #7, it's an '89.
Old Mar 12, 2004 | 10:42 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
#5 & #7????
Old Mar 13, 2004 | 08:19 PM
3rdgenstm's Avatar
Car: ‘92 Z28
Mine has the 12 pin diagnostic connector. From right to left it is 1,2,3,4,5,6 on the top row and 7,8,9,10,11,12 on the bottom. Take the paper clip and stick one end in the #5 terminal and the other in the #7. Trun the key to on and wait for the grounded code '12'. It will be a flash, short pause, flash, flash. Then a long pause, 12, long pause, 12. Then it willstart flashing codes after that in the same pattern. When it is finished, it will flask '12' again. If you don't get the '12' code, it isn't hooked up right.
Old Mar 13, 2004 | 09:47 PM
AJ_92RS's Avatar
Huh. This is what it says on our home page, and in 2 other books I've read.
DISPLAYING THE TROUBLE CODES
Run a wire/hairpin from Pin 6 to Pin 12 with the ignition off (although on later cars it should be from Pin 5 to Pin 6), then turning the ignition to the on position without starting the engine will flash the "Service Engine Soon" light in the following sequence: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause Following this "12" code repeating three times will come any trouble codes stored, flashing each of them three times. If you do not see the "12" flash three times, your diagnostic circuit is defective.
Just seems weird that your car is the only one that uses those pins.
Old Mar 13, 2004 | 10:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Interesting that he can get those codes by jumping pin "5" & "7" or pin "B" & "G" as they are labeled. Pin "B" is for the ECM signal and pin "G" is for the fuel pump signal. The proper pins to jumper is the pin "B" & "A", or if you want to number them. It would be pin "5" & "6" going left to right and top to bottom. Here is a schematic of the 89 RS LO3 ALDL.
Old Mar 13, 2004 | 11:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here's another one.
Old Mar 14, 2004 | 08:53 AM
3rdgenstm's Avatar
Car: ‘92 Z28
5&7 work for me, so get off my ***.
Old Mar 14, 2004 | 09:11 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
3rd, I'd probably stop doing it that way. It is conceivable you are getting it to ground through the fuel pump, but were I you, I'd do it the right way. Name them anything you want, but stop doing it it half-assed.
Old Mar 14, 2004 | 04:05 PM
3rdgenstm's Avatar
Car: ‘92 Z28
I don't think there is a half-assed way to do it really and I am not trying to be an assh0le or anything. But here it is. I tried the 6 and 12 terminal combo and they didn't work. There is nothing in the 8 terminal, so I can't jump there. That's when I was told to jump the 5&7 combo (from another web site) and it worked. If that isn't correct, ok. Here's a pic of my connector. Show me which ones to jump other than the 6&12, cause it doesn't work that way.
Old Mar 14, 2004 | 04:19 PM
3rdgenstm's Avatar
Car: ‘92 Z28
Oh, the light just stays 'lit' when it is in 6 & 12 (A&M). It doesn't flash or go off and then start. It just stays lit.
Old Mar 14, 2004 | 04:25 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
91 RS 305tbi
These 2.
Edit: Sorry, your right, and now i'm confused, reading all this has made me forget which ones I used damnit, so ill let you guys figure it out.
Old Mar 14, 2004 | 04:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by PyRo9862
91 RS 305tbi
These 2.
Pyro,
you're contradicting yourself. Read your first post.
Old Mar 14, 2004 | 04:37 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Yeah, ive sucessfully confused myself.
https://www.thirdgen.org/techbb2/sho...ighlight=paper
Vader has a nice diagram.
Old Mar 14, 2004 | 08:20 PM
3rdgenstm's Avatar
Car: ‘92 Z28
So, will 5 & 6 (A&B) do it correctly?? I don't want to do anything to the car that will fry the ECM or something. I want to do it the correct way. As I said, that way I described earlier in the post is what I was told to do. Let me know.
Thanks for the help.
Old Mar 14, 2004 | 08:23 PM
I've used 5&6 on my '90 RS with no problems. Seems to work OK.
Old Mar 14, 2004 | 08:25 PM
3rdgenstm's Avatar
Car: ‘92 Z28
Cool. I'll try that and use it in the future.
Old Mar 15, 2004 | 06:49 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by 3rdgenstm
...I tried the 6 and 12 terminal combo and they didn't work. ...Here's a pic of my connector. Show me which ones to jump other than the 6&12, cause it doesn't work that way.
Ahh. It's 5&6 the way you see it. If you go to the link above we all call it A&B terminal. The two top right terminals.
I'll steal from Vader:
The one marked ecm diagnostic request and the ecm ground. I just don't know what putting only 5 volts to your fuel pump will do to it over time.
Old Mar 16, 2004 | 06:03 AM
3rdgenstm's Avatar
Car: ‘92 Z28
Thanks for the help! Haven't had a chance to try it yet, but I will do it like that from now on.
RS Reaper
Oct 17, 2018 07:52 PM
Night rider327
Feb 25, 2016 09:50 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
RS Reaper
Sep 27, 2015 07:04 PM
