oil pressure guage?
Old Mar 12, 2004 | 03:15 PM
RedRoc89's Avatar
Car: 89 Iroc-z
Transmission: 700R-4
oil pressure guage?
Can anyone help me here my oil pressure guage is all jacked uped
when i was driving today the needle shot up to the top and stayed there untill i stopped then it went to zero,as i hit the acelerator it moved up alittle then shot to the top again, I pulled in at my apt and turned it off and its at the top.What's going on here a bad guage or something seriously wrong.Oh by the way I checked the oil and its good.
Old Mar 12, 2004 | 04:24 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Probably a bad oil press. sending unit. Its in back near the firewall.
Old Mar 12, 2004 | 04:40 PM
ede's Avatar
ede
yeah change the sender and see if it helps, cheap and easy to do. on the china wall near the distributor
Old Mar 13, 2004 | 06:55 PM
RedRoc89's Avatar
Car: 89 Iroc-z
I replaced the sending unit that did the job,thanks guys for your help.
Old Mar 24, 2004 | 03:22 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
I have a similar problem:
cruising: 30psi
at idle 15psi
after idling for a few seconds: 0 psi
this doesnt happen all the time though
today the needle bottomed out then at cruising only went up to 15psi then slowly walked up to 30psi
do you think this is the same or should i be concerned with my oil pump?
i have tried looking for info in my haynes manual, none.
Old Mar 24, 2004 | 03:57 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
you should put a mechanical oil pressure gauge on the engine and verify if that reading is correct or not, if it is, it sounds like it`s time for an engine upgrade
Old Mar 24, 2004 | 05:11 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
I was thinking about a mechanical guage.
the motor is running fine(i think). this has been going on for 2 weeks i think. and it is intermittent. if the pump was going bad, would it just go out or fluctuate?
Old Mar 24, 2004 | 05:26 PM
probably would pump or not pump, but you never know.
Old Mar 24, 2004 | 06:33 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
well i have a mechanical lying around. just need a few fittings, or should i just try replacing the switch? or both? is there really any way to check if the pump is at fault without dropping the pan?
Old Mar 24, 2004 | 06:56 PM
Tap into the block just above the oil filter, there is a sending unit or a pipe plug there, remove it and put the gauage in there and see what the Actual pressure is......or start replacing parts
Old Mar 26, 2004 | 05:50 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
well i replaced the sending unit, and now it is stable.
at idle it sits about 17psi and under load about 30.
i am going to put in the mechanical this weekend, need to find the metal tubing. i found a plugged hole at the bottom just above the oil pan it points down @ about 45* would this be acceptable location for the mechanical hookup?
Old Mar 26, 2004 | 06:46 PM
unless you want a coolant bath, don`t pull that one. look straight up above the oil filter. I`ve never seen a oil pressure gauge that needs metal tubing, mine has a five foot rubber hose.
Old Mar 26, 2004 | 07:40 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Buy a pre assembled Braided line, just for security because rubber melts and wears. summit sells them along with Jegs. Plus Many engine builders will tell you as long as you have 10-15 psi of oil pressure Per 1000 Rpm,you are ok as long as the needle dosen't jump be cause there might be a cavity in the pump or cloged screen. many will flame me for that but oh well Just my .02
Old Mar 26, 2004 | 09:27 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
it is just a tapped and plugged(metal plug) hole, below the oil filter just above the oil pan.
besides i already had my hot coolant bath the other day when i replaced the knock sensor. that was not fun(thank you thick skin)
two weeks ago i got my gas bath replacing the filter( forgot to open gas cap and relieve pressure). and i also knocked over the catch can with fuel in it. just about stripped my hands of all the thick callous(sp) skin they were almost baby smooth
my mechanical came with nylon tubing, but i want to use some copper tubing instead, it doesnt need it, just want it
Old Mar 27, 2004 | 05:08 AM
I know what your saying Gas baths are the worse but that plug your talking about is a coolant drain LOOK ABOVE THE FILTER
Old Mar 27, 2004 | 07:41 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Isn't the oil pressure sending unit mounted above the oil filter on an 89 TPI?
I have the same problem with the gauge and I don't want to be replacing a good unit?
RedRoc89, what is the part number for the sender????
Thanks..
Old Mar 28, 2004 | 11:53 AM
RedRoc89's Avatar
Car: 89 Iroc-z
DANIELEK,
not sure on the part # I had a local performance shop replace mine.
Old Mar 28, 2004 | 09:00 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Thanks..
AFAIK, that origionally was used for the 'choke' light in the dash on the carbed cars but now only serves as a backup switch for the fuel pump.
Old Mar 29, 2004 | 09:49 PM
SNIPING92BIRD's Avatar
Car: 1989 GTA / 92 Z28
Engine: 350ci
Transmission: 5 speed
i had this prob on my car as well the pressure was dropping and then rising back to norm...sometimes stayed at 0 for a bit them went back up...i thought it was the oil pump well maybe it was but i kept driving around with the prob...till it was time to take the engine apart(upgrading)...i was surprised what i saw when i took that intake manifold off...i dont know how to explain the fact but the oil left in there was so thick that if you stick a spoon in it will stay up...i barely reached the head bolts...no wonder my oil pressure was droping....oh and i did changed the oil regularly sometimes even too early...and the car is with 133K miles on it
Old Mar 29, 2004 | 09:59 PM
killerbeeiroc's Avatar
Car: 1988 Camaro IROC-Z
Transmission: Borg Warner T5s
One of you said you got a coolant bath when you changed your knock sensor. Well I replaced mine today and only got a tiny drip of coolant from the hole. Is this normal? I've been getting an code 43 from the computer and its why I changed the sensor. Let me know.
Old Mar 30, 2004 | 12:31 AM
Car: 88 Camaro SC
Engine: SFI'd 350
If there is alot of deposits in the water jacket the coolant may not drain out. Generally, though, even with the radiator drained down, there will be more then enough coolant in the block to really make a mess if your not prepared for it.
Old Mar 30, 2004 | 01:27 AM
So I shouldnt worry that I had no coolant leaking out?
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
