Harmonic Balancer OD?
Old Mar 13, 2004 | 05:06 PM
My86TransAm's Avatar
Ok, ive searched the boards for about the last hour and havent found the exact answer to my question. I have found out that my Harmonic Balancer is slipping and rubbing against my timing chain cover, and has started a small oil leak. So, Im picking up a 2 piece timing chain cover and a Harmonic Balancer. Im buying the Summit Brand balancer, since im on a budget it, and 5,000 RPMS doesnt justify the use of a fluidamper.
My question is, what size do i need? I have a 305 TPI car. Is it the 6 3/4" or the 8"?
Old Mar 14, 2004 | 07:02 AM
ede's Avatar
ede
why don't you measure the one you have and you'll know 100% for sure what you have and need. doesn't really make much sense that the balancer could rub a hole in the cover and start a leak. the hub or the part the fits into the cover is the same size on all dampners and can only fit onto the crank so far.
Old Mar 14, 2004 | 07:18 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
oh...that's really a common problem. the outer ring separates from the inner ring and works its way into the timing cover. it's only held together by a rubber isolator ring...and when it separates, it just slowly slides in toward the engine. that happened to my car..just replace it.
Old Mar 14, 2004 | 12:39 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Make a guageing tool from scrape wood and slide under
the car and try it over the balancer. if it doesn't fit
you have the larger balancer.
Old Mar 14, 2004 | 12:43 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Although a great idea, that's too much work. Cutting out a notch in cardboard is much easier.
Old Mar 14, 2004 | 01:15 PM
ede's Avatar
ede
i've heard of and even seen a few dampners where the outer ring moved but never seen one cut the timing cover. guess my dumbass learned something here
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
