87 350 L98 engine ?'s Please help!
Old Feb 19, 2001 | 10:06 PM
whiteboy's Avatar
I have an 87 IROC that has a 350 L98 in it. The TPI system was removed for numerous reasons and I am now going with a carb. I was wondering if I had to use the 87-95 style heads on this car because of the way they mounted to the block? Or can I change heads to the pre 87 style allowing me to use a wider selection of manifolds? Upon hearing the results of this, could you guys also suggest a manifold to use, I have a 355 with a ZZ3 cam looking for performance over economy, thanks!
Old Feb 19, 2001 | 10:36 PM
Vader's Avatar
WB,
You should be able to bolt the older perimeter bolt style heads to the case with no alignment or fitment problems. The only SBC heads you can't bolt on are the LT1/4 and LS1/6 heads.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 19, 2001 | 10:52 PM
whiteboy's Avatar
Thanks Vader!! Thats exactly what I needed to know! Any suggestions on what intake to use?
Old Feb 20, 2001 | 12:00 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
dont change your heads unless you are going aftermarket! The L98 heads are nice and you could just grind on the center holes to make an older intake bolt up to the newer heads. check out the holley PN-300-70 intake or the performer PN-2104 intake. Dont chuck those heads for some ****ty castings just so you can use a different intake!
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
