Resistor variance for VATS bypass
Old Feb 19, 2001 | 09:05 PM
Mike-91 Formula 350's Avatar
Does anyone know if the VATS bypass resistor outlined in tech has to be exactly the same.I checked my key with 2 different meters and one read 520 the other 528.Thanks Mike
Old Feb 19, 2001 | 11:56 PM
Andy89RS's Avatar
It doesn't need to be dead on. Just get the closest resistor you can find at your local Radio Shack.
Old Feb 20, 2001 | 12:43 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Yeah - if you think about it, it CAN'T be dead on: the current has to flow through quite a bit of wire (mostly tiny wire that certainly ups the resistance) so there must be variance. As a rule of thumb if there are two close choices get the one with lower resistance, or for $.50 a pop, get both. I mean there's frugality and there's just plain CHEAP!
"Among so many conflicting ideas and so many different perpectives, the honest man is confused and distressed and the skeptic becomes wicked...Since one must take sides, one might as well choose the side that is victorious, the side which devastates, loots, and burns. Considering the alternative, it is better to eat than to be eaten."
Napoleon I
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
studebaker60
Sep 7, 2015 12:36 PM
