What kinda lifters?
What kinda lifters?
Hey guys, been awhile. Just bought an 89 Trans Am LO3, looking to put a cam into it but new to this engine. What kinda lifters are in here roller or flat tappets? Also what is the weakest point on this motor which I should work out? Thanks, just gettin some simple pointers.
Transmission: 4L80E/4L80E
Look over on the TBI forum. They'll set you in the right direction.
(BTW, roller lifters. Typically, they can be transfered to the new cam.)
Car: Firebird Pro/Am
Engine: Modified 350
Axle/Gears: 3.08 Posi
get a roller cam. The roller lifters allow you to increase your amount of lift, since they can go at a steeper angle than their tapet counter-parts. Thus, the power curve increases greatly with a roller lifter. There is a difference, just make sure you buy a cam that says "for hydrolic roller lifters." they're actually quite common. I'm running Comp Cams hydro-roller lifter cam.
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
dimented24x7
Sep 6, 2015 03:51 PM
