PCV valve ?
Old Mar 15, 2004 | 11:08 AM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
PCV valve ?
Can I just hook the PCV valve straight to the carburetor with a single hose, or do I need to take it through the other routing system that is on the engine?
Adam
Old Mar 15, 2004 | 06:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You probably could, although if it is still computer controled it might not run quite right. Do you plan to remove all the emission equipment and plumbing?
Old Mar 15, 2004 | 07:08 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
you can but you no longer have the evap emmissions and sucht hat run off that main vacuum feed.
Old Mar 15, 2004 | 09:49 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Yeah, I was planning on taking just about everything else off that is involved with emissions. I am also getting rid of all the computer control.
Old Mar 15, 2004 | 10:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yes. Thats what I did. One hose from the PCV valve to the carb is fine.
tyeo098
Nov 30, 2015 06:27 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
